Technical help for Lui, Vega, Cometa, J50, Cento, J125, Starstream.
by grumpar » Sun Oct 02, 2016 2:11 pm
Hi i have a quite bad copy of a luna 50 manual showing 3 washers ? on the engine gear control lever i would imagine one is a oil seal with it going between the inside and outside of the engine but can anyone give more detail or post a detailed pic cheers
grumpar
by 57Speedster » Mon Oct 03, 2016 1:28 pm
Hi, Not sure if Luna is exactly the same as other J Range, but there is a good parts book on here :
http://www.scooterhelp.com/serial/cento.parts.htmlMy Cento Gear selector shaft has 2 washers, and an O ring oil seal which fits in a groove at the top (lever) end of the shaft.
57Speedster
by grumpar » Mon Oct 03, 2016 4:37 pm
Thanks for the reply Speedster just what i needed, cheers
grumpar
by Bindog » Tue Oct 04, 2016 6:03 pm
Hi anybody ever taken a brass stealing lock out of a Lui ,it's side mounted type not the bolt on font one and its in the unlocked position I have no key thanks
Bindog
by mickey c » Fri Oct 07, 2016 12:55 am
If it's like a vega lock, there are 2 square shims slid down the front of the lock, tap these out with something thin, the o'clock will come out if these are removed.
mickey c
Return to Luna & J Range
