by pat12966 » Sun Oct 16, 2016 10:35 am
HI, they were fitted to a standard innocenti GP 200. They were new so, I left them on .I had the engine rebuild & then last week when I went for a ride for the first time, I did not go over 45mph as the vibrations were too muchi! It was horrible to ride & I could not wait to get home. I have now replaced them with uni 3 hole mounts, it has transformed the scooter
pat12966
by HxPaul » Sun Oct 16, 2016 10:54 am
pat12966 wrote:HI, they were fitted to a standard innocenti GP 200. They were new so, I left them on .I had the engine rebuild & then last week when I went for a ride for the first time, I did not go over 45mph as the vibrations were too muchi! It was horrible to ride & I could not wait to get home. I have now replaced them with uni 3 hole mounts, it has transformed the scooter
Read this
http://www.scooterotica.org/forum/viewt ... ine+mounts
by Tractorman » Sun Oct 16, 2016 11:04 am
I had mine on for 15 miles and changed them.
by burnside » Sun Oct 16, 2016 3:28 pm
Had mine on for 2k miles, they improve a lot after around 500 miles. I tend to get most vibrations at around 45-50 mph, but over that speed don't feel any
burnside
by Tony Hart » Sun Oct 16, 2016 4:21 pm
As above. They seemed to sort themselves out after about 500miles on a Mugello 186 engine
Tony
Tony Hart
by Tractorman » Sun Oct 16, 2016 5:41 pm
Perhaps the vibrations alter the molecular structure of the rubber
by Tony Hart » Sun Oct 16, 2016 5:50 pm
Tractorman wrote:Perhaps the vibrations alter the molecular structure of the rubber
Or my a**e has become numb to the sensation
Tony Hart
by xenia1 » Mon Oct 17, 2016 8:57 am
Any type of rubber mount whether engine/ gearbox/ two/ four wheels goes softer with age and use, the scootopia mounts would most likely have been fine after a few hundred miles or so and with their harder compound will also most likely outlast others with a softer make up..
xenia1
by Tractorman » Mon Oct 17, 2016 9:10 am
xenia1 wrote:Any type of rubber mount whether engine/ gearbox/ two/ four wheels goes softer with age and use, the scootopia mounts would most likely have been fine after a few hundred miles or so and with their harder compound will also most likely outlast others with a softer make up..
You could corner the market by selling bedded in scootopia engine mounts
by burnside » Mon Oct 17, 2016 9:32 am
Tractorman wrote:xenia1 wrote:Any type of rubber mount whether engine/ gearbox/ two/ four wheels goes softer with age and use, the scootopia mounts would most likely have been fine after a few hundred miles or so and with their harder compound will also most likely outlast others with a softer make up..
What mounts are you using on your combo? I'm using the RLC sidecar mounts, now that are super hard and vibrations are mental with these, I did fit some bubble grips which have helped but I would struggle to ride any real distance....but maybe these will settle after a few thousand miles
burnside
by pat12966 » Mon Oct 17, 2016 11:27 am
I am using scootopia mounts as paper weights,i don't thing my teeth bum hands arms could wait for 500 miles
pat12966
by Tractorman » Mon Oct 17, 2016 4:24 pm
burnside wrote:Tractorman wrote:xenia1 wrote:Any type of rubber mount whether engine/ gearbox/ two/ four wheels goes softer with age and use, the scootopia mounts would most likely have been fine after a few hundred miles or so and with their harder compound will also most likely outlast others with a softer make up..
I use the AF double on the r/h side and a SIL one on the left. I had thought about the RLC when I change but am pleased with your feedback.
by Kev Fox » Wed Oct 19, 2016 9:43 am
Fitted Scootopia engine mounts to my SX. The vibration was noticeable instantly. Have ran it for 700 miles now and they are shaking my scooter to bits. I have ran it hoping they would improve with time but sadly not. Scooter is apart now for a refurb and those mounts are coming out.
Kev Fox
