Cylinder Heads
Cylinder Heads
Postby St George » Fri Aug 08, 2014 4:28 pm
What is the basic difference between a 225 and standard 200cc SIL head. Is the combustion chamber smaller on the 200cc or bigger. I have just fitted a new 200 head from AF and don't seem to have the same power or revs. Cheers.
St George
Re: Cylinder Heads
Postby Knowledge » Fri Aug 08, 2014 8:17 pm
Have you fitted a new 200 head to a 225 (70mm bore)?
Re: Cylinder Heads
Postby St George » Sat Aug 09, 2014 6:03 pm
No I have a Yammy 60 mm con rod, AF crank and a 3 mm spacer and cut down piston. I think they call it a stroker. The heads looked the same. I might just advertise for a bog standard 200 engine. Just want to plod about at 55 mph. Shame it's just run in.
St George
Re: Cylinder Heads
Postby Knowledge » Sun Aug 10, 2014 8:44 am
You are describing a good selection of parts there George, but the tone of your reply is that you're a bit disappointed.
What problems are you experiencing? Why are you looking at the cylinder head? What barrel and bore are you currently running?
With a bit more info, we might be able to offer some useful advice.
Re: Cylinder Heads
Postby St George » Sun Aug 10, 2014 12:36 pm
Standard size barrel which has been nicely ported to stage 4. Piston is new and cut down on inlet. Just don't rev or pull that well in 4th gear. May put the 48 mm AF Clubman back on despite the noise. All input welcome. The plug is the right colour. I know that this engine can push out the BHP. Thanks.
St George
Re: Cylinder Heads
Postby Scooterlam » Wed Aug 20, 2014 2:30 pm
Sounds like a possible gearing issue.
What pipe are you using at present.
Scooterlam
Re: Cylinder Heads
Postby CHRIS in MARGATE » Wed Aug 20, 2014 4:35 pm
What pipe and gearbox ?
Re: Cylinder Heads
Postby St George » Wed Aug 20, 2014 5:37 pm
Hi Chris, How are you mate. I think it is the bog standard Sil 200. It used to fly with a 30 delly and JL 4. I used to have a standard GP 200 and that was quick ? My current exhaust is a new GP 200 system I bought from AF and the carb is a new Jetex 22 SH. I have jetted it up and down in all departments. I will probably SORN the old girl and play with it over winter. Thanks for the reply Chris.
Colin
St George
Users browsing this forum: Bing [Bot] and 18 guests
