Trimmed side panels
Trimmed side panels
Postby gizmo » Mon Oct 31, 2016 9:06 pm
How's best to finish edges off after trimming side panels. Can they be folded over as originally done
gizmo
Re: Trimmed side panels
Postby xenia1 » Mon Oct 31, 2016 9:20 pm
Any type of steel panel once cut should really be folded at the edge for rigidity, an alternative is a piece of 3-4mm round steel rod welded to just above the edge and then folded under the steel rod..
xenia1
Postby gizmo » Mon Oct 31, 2016 10:07 pm
xenia1 wrote:Any type of steel panel once cut should really be folded at the edge for rigidity, an alternative is a piece of 3-4mm round steel rod welded to just above the edge and then folded under the steel rod..
Thanks for that. So you would weld the rod to the back of the panel and then turn the panel edge back. Then weld the joint at the top ? To seal it
gizmo
Postby xenia1 » Mon Oct 31, 2016 11:30 pm
Yes, use a mig welder though on a low setting and spot weld rather than seam weld to minimise distortion. Grind the welds down with a dremel drum disc for a neat job and use a thin bead of seam sealer afterwards along the joint before painting..
xenia1
Users browsing this forum: No registered users and 8 guests
