Digger wrote:Warkton Tornado No.1 wrote:
The recommendation for a GP crank seems reasonable, though I've never witnessed a failed Li taper crank.
Really?![]()
That looks to me like corrosion cracking. That's when corrosion causes a minute crack which propagates over an extended period. IF that were the main cause of li style cranks failing, then it would go a long way to explain why they didn't fail on 70s race engines; they simply hadn't had enough time to deteriorate by then.
