Phil D wrote:Hi Andie
I think you've probably " hit the nail on the head " nylocks loose their ability to grip the thread when they are repeatedly used .
Its best to use new ones if poss.
Especially on Lambretta
peejay wrote:hi Andie
i know you have now got the engine back together and running.
have you used an ethanol resistant gasket, this is most important.
i make my own now after an ordinary shop bought one blew out some time ago.
you can buy small pieces of various thicknesses quite cheaply.
rossclark wrote:Check the gasket match on the barbell and trim to fit, then recheck on the manifold. That should tell you how to match the manifold to the inlet port.
xenia1 wrote:peejay wrote:hi Andie
Peejay makes a good point. There are many materials that are not ethanol compatible, this site lists those which are and which are not. It lists aluminium but as the manifold is an alloy i doubt this would apply..
http://iqlearningsystems.com/ethanol/do ... bility.pdf
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 6 guests
