Jim Rose wrote:How do I get in touch with Ian Franklin for the tapered bearing? Ideal for my project
Digger wrote:Jim Rose wrote:How do I get in touch with Ian Franklin for the tapered bearing? Ideal for my project
He's on FB...
Knowledge wrote:No. the top of the tube is machined to suit the upper bearing race. When you cut an inch off the fork stem, you cut off this machined section and are left with a tube that is too narrow for the original bearing race.
This is a problem, but there are solutions.
You can use the smaller top bearing race from the chrome ring and machine a spacer between the tube and the smaller bearing race. Alternatively, you can buy one of the new tapered bearing conversion from Ian Frankland, which offers an option for this specific scenario.
Knowledge wrote:Gizmo,
I will be doing the conversion over Xmas, so I will take some photos and post them up on here, but meanwhile I will try to explain in words. It does involve some mistreatment of a chrome ring though, and people of a sensitive nature might wish to look away now.
I have undertaken this work on chrome-ring scooters when I have converted them to GP spec.
1. Remove the chrome ring with the top race in place.
2. Cut the inch off the top of the stem to give the GP/DL length of tube.
3. Remove the halo from the chrome ring, but leave the lug that acts as the stop for the steering lock
4. Carefully measure the ID of the cut-down steering tube. Measure twice, cut once.
5. Put the remainder of the chrome ring into a lathe and turn-down the OD of the chrome ring, to create a spacer, but leave a flange on the top so the remainder of the chrome ring doesn't slip down the steering tube.
6. Slot this into the top of the steering column tube with a nice, tight interference fit with the upper bearing track in place.
If you don't have a chrome ring to hand, find a section of tube that is the right dimensions, and make your own spacer from scratch, though you will have to fabricate your worn lock-stop too.
I hope this is helpful
Phil D wrote:Hi F & F
Just reading with interest your post about lower bearing race upgrade to taper bearing .
Would it be possible to use the old bearing race to house the new taper bearing .
It would save some work.
Fast n Furious wrote:Phil D wrote:Hi F & F
Ahh. If it were that easy Phil then it would have been a popular conversion years ago. Sadly, the old bearing cup has to go and a new cup needs to be made from mild steel so it can accept the loose outer taper shell of the new taper bearing assembly. I should have drawn this up when I did it, but its a straight forward job for a machinist if he has the old cup and the new taper bearing. You can dispense with the dust seal shield as the new bearing has a built-in oil seal.
I wish I'd done the same to the top bearing but that requires additional work to the top of the fork columb, which will probably mean that you can no longer use a traditional speedo cable and may need a collar making so you can still clamp the headset bracket on. There are ways around this but they involve more exotic adaptions.
