Targaline Gear Change Assembly Help
Postby ROClarke » Sun Jan 15, 2017 10:23 am
Morning all
Can anyone tell me what the 2 oils seals are for as supplied with the Targaline gear change kit ? :?
ROClarke
Re: Targaline Gear Change Assembly Help
Postby Toddy » Sun Jan 15, 2017 10:25 am
ROClarke wrote:Morning all
Any pictures ? Can't see any on the advertising pictures
Postby bike grim » Sun Jan 15, 2017 11:42 am
Are they instead of a gasket under the swivel mount? I didn't use mine.
Postby ROClarke » Sun Jan 15, 2017 12:38 pm
Here is a pic of ebay but got mine from Cam Lamb,same kit more or less.
http://picclick.co.uk/Lambretta-Targa-L ... 10027.html
ROClarke
Postby ROClarke » Sun Jan 15, 2017 12:40 pm
bike grim wrote:Are they instead of a gasket under the swivel mount? I didn't use mine.
No inside diameter too big for the bolts,just doesn't look right,think they should actually go one swivel mount.
ROClarke
Postby HxPaul » Sun Jan 15, 2017 12:49 pm
I dont see any oil seals in that photo,I can see one o-ring that goes on top of the gear swivel.
Postby ROClarke » Sun Jan 15, 2017 1:46 pm
HxPaul wrote:I dont see any oil seals in that photo,I can see one o-ring that goes on top of the gear swivel.
Sorry mate, that is what I meant, Cheers !
ROClarke
Postby Knowledge » Sun Jan 15, 2017 2:34 pm
Blimey, £90. :shock:
Postby bike grim » Sun Jan 15, 2017 4:07 pm
Is it important to have this o ring on then? I may have to have a look at mine (Mike Phoenix sells them much cheaper than that eBay advert)
Postby Delboyli150 » Tue Feb 21, 2017 9:41 am
On the gear swivel axel, o ring, gear swivel, o ring then circlip. Tight but you can get it on. A lot of people do not bother but hey there must be a reason , think it might be to keep dirt out so then prolongs wear and tear. :D
Delboyli150
Postby gizmo » Fri Jan 03, 2020 1:56 pm
Found this post while looking for an answer to the o ring issue. Did you remove the o rings from above and below the swivel. I can understand the keeping dirt out reason but the swivel is very stiff with them fitted
gizmo
Postby ROClarke » Fri Jan 03, 2020 11:28 pm
Bloody hell, so long ago I forgot, I think I just used one on top of the swivel and assumed the extra one was a spare.
ROClarke
Users browsing this forum: Baidu [Spider] and 14 guests
