Dual Seat fittings
Dual Seat fittings
Postby landybretta » Wed Jan 18, 2017 2:56 pm
I know that there should be plastic washers between the seat locking plate and the frame but should there be any type of washer between the hinged plate at the front of the seat and the frame. Series 3 LI 150 Special.
landybretta
Re: Dual Seat fittings
Postby ToBoldlyGo » Wed Jan 18, 2017 3:28 pm
I suspect the correct answer is plain washers. However, I always use 1/2" tap washers myself. You have to open up the hole a little, but it works a treat. The difference is probably minimal, to be honest, but it has to have a little effect on vibration.
ToBoldlyGo
Postby lammydave » Wed Jan 18, 2017 10:21 pm
I always use the same nylon washers as the rear catch
lammydave
Postby corrado » Wed Jan 18, 2017 11:32 pm
I bought a sheet of 6mm rubber and made gaskets the same size as the seat catches. I have a side catch on the seat and it was very close to the paint work so these gaskets give it more clearance plus no washer indentations in the paint work.
corrado
Users browsing this forum: Bing [Bot] and 20 guests
