My sip speedo appears to have broken because my regulator went as normal all the bulbs went, but I didn't expect the speedo would break.
Is this normal for sip speedos
tottn15 wrote:My sip speedo appears to have broken because my regulator went as normal all the bulbs went, but I didn't expect the speedo would break.
Nelly wrote:Yep,
A regulator pumping out unregulated voltage could very easily fry a SIP speedo. I would always recommend fitting a fuse to at least attempt to save the electronics in the event of a regulator over voltage. There's a good chance it would still fry due to the voltage that would appear but the fuse would limit the flow of current, which should limit the power going through the electronics.
I don't seem to remember the speedo having a fuse fitted as supplied. I fitted a 2A fuse to mine, I seem to remember.
Funny stuff electrickery.
tottn15 wrote:could it be the little black box rather than the speedo itself
tottn15 wrote:it was the little black box i have put in anew one and all is ok but the clock it now reads 3f 5c but i can live without a clock ,thanks to everyone for you time and help
