A bit of advice....again
Postby Charliebubble47 » Sun Feb 05, 2017 9:24 pm
Hi gents
I fired up my scoot for a blast along the back lanes yesterday, kicked over no problems and warmed up for about 10 mins. Took her out but as soon as I changed down the gears it started to bog down and then it stalled and wouldn't kick over I pushed it back to my garage and checked the spark plug, which was black and oily, so I changed it for a new. I had one of those inline fuel filters on so I removed that and renewed the fuel line, changed the fuel and swapped the carb over for a spare jetex I had.
So I today I fired her up, no problems let her tick over for a good 20 mins with no problems, took her out but as soon as I got into 3rd gear bogged down again and conked out. Pushed back to the garage but she wouldn't kick over. Spark plug black and oily. I checked the fuel flow rate when I changed the fuel line.
It's a electronic ignition if that makes a difference
Any advice will be most grateful
CB
Charliebubble47
Re: A bit of advice....again
Postby Fast n Furious » Sun Feb 05, 2017 9:29 pm
The content of your post suggests the engine is finding it hard to breath. Check your air filtration. (Have you left anything under the seat that could block the breather scoop?)
Postby MickYork » Sun Feb 05, 2017 9:34 pm
Need more info'.
What scoot is it ?
Is it kitted ?
What carb' and settings ?
Open mouth or filter ?
Advance/retard ignition ?
What is ignition set at ?
etc
etc
Sounds like your bogging down .....too much fuel to air ratio...
or it could be stator breaking down........cooling.....then working again.
Have you got a Sticky's manual ? worth getting one and having a read.
Postby Charliebubble47 » Sun Feb 05, 2017 10:12 pm
Fast n Furious wrote:The content of your post suggests the engine is finding it hard to breath. Check your air filtration. (Have you left anything under the seat that could block the breather scoop?)
It breathes through a ram air remote filter and there isn't a air scoop it's Spanish and used to breathe through the tool box but I will check the filter for cracks or a blockage
Charliebubble47
Postby Charliebubble47 » Sun Feb 05, 2017 10:25 pm
MickYork wrote:Need more info'.
What scoot is it ?
Is it kitted ?
etc
etc
Serveta lynx 125 but with a 186 kit on
22mm jetex carb don't know what the jets etc are but will have a look tomorrow and it has a ram air remote air filter and a standard clubman exaust
Don't know the advance/retard ignition or what it's set at
I have a spare stator so will look at putting that on if all else fails
Thank you
Charliebubble47
Postby MickYork » Sun Feb 05, 2017 11:31 pm
try it without the air filter.......
Postby Charliebubble47 » Mon Feb 06, 2017 12:19 am
MickYork wrote:try it without the air filter.......
Will give it a go tomorrow and see what happens
Out of curiosity what would be the best set up on the carb,
just looking at stickys book and my carb is set up for a gp150
Slide:7895-2
Atomiser:5899-4
Main jet:118
Pilot:45
Starter jet:50
Would this be causing the problems
Charliebubble47
Postby coaster » Mon Feb 06, 2017 12:38 am
Are absolutely certain that your choke is closing properly? there should be a bit of slack at the carb end when it is in the off position.
Postby Charliebubble47 » Mon Feb 06, 2017 12:50 am
coaster wrote:Are absolutely certain that your choke is closing properly? there should be a bit of slack at the carb end when it is in the off position.
Will have a look at this tomorrow
Charliebubble47
Postby lammydave » Mon Feb 06, 2017 6:50 am
make sure your petrol tank cap is breathing
lammydave
Postby CHRIS in MARGATE » Mon Feb 06, 2017 7:42 am
Agree it sounds like an inability to breathe. What has changed ? Is this a new fault or has it always been like this ?
Postby HxPaul » Mon Feb 06, 2017 10:56 am
Slide:7895-2
Atomiser:5899-4
Main jet:118
Pilot:45
Starter jet:50
If its a 186 top end,your carb needs setting up as a 200
Slide:7895-1
Atomiser:5899-2
Main jet and pilot may need altering,but they will get you running and you can fine tune them from there.The choke jet is the same in a 150 carb or 200 carb.
Postby EddieStone » Mon Feb 06, 2017 11:14 am
Sounds like a choke fault to me.
EddieStone
Postby Rich Oswald » Mon Feb 06, 2017 12:03 pm
lammydave wrote:make sure your petrol tank cap is breathing
+1
Postby missing lynx » Mon Feb 06, 2017 12:28 pm
when was the last time you cleaned the air filter?
Postby Charliebubble47 » Wed Feb 08, 2017 11:45 pm
Cheers gents I think I've got it beat......sticky choke.
There was no slack on the choke cable so slacken it off and checked the choke action when I had the ail filter off to check that and for good measure I checked the fuel cap breather it seamed ok but I gave it a goo dream out with a strand of copper wire.
I gave it a blast out last night with no apparent problems....fingers crossed and all
Once again thanks for all the sound advice
CB
Charliebubble47
Users browsing this forum: Google [Bot] and 6 guests
