Chain case studs
Chain case studs
Postby Watfordwhite » Sun Feb 19, 2017 6:18 pm
Going to replace mt change case bolts with stainless Allan studs. Anybody know what length and size please?
Watfordwhite
Re: Chain case studs
Postby Digger » Sun Feb 19, 2017 6:31 pm
Allan studs? I assume you mean bolts?
If so be aware that they used studs for a very good reason - steel is much tougher than the alloy that they screw in to.
Digger
Postby MickYork » Sun Feb 19, 2017 6:37 pm
Postby Wack » Sun Feb 19, 2017 7:02 pm
Take out your old studs and measure,I think the side casing ones are M6x 40 mm.I have a set in the shed but buy them from other traders on Ebay as they are considerably cheaper than a scooter dealer and I use nylock flange nuts so no messing with washers.http://www.ebay.co.uk/itm/321249479526? ... EBIDX%3AIT http://www.ebay.co.uk/itm/M4-M5-M6-M8-M ... ADmDeMjizw
Postby corrado » Tue Feb 21, 2017 2:41 am
I wouldn't use stainless, I use Black high tensile ones and I never use nylock on studs as it can draw the stud out when removing.
corrado
Users browsing this forum: No registered users and 30 guests
