by P D: SC Chester » Wed Mar 08, 2017 8:51 pm
I have a PWK 26mm carb and have fettled the soldered end on a 'cheese head' type cable (from Scooropia with brass nipple), to fit in the D' slide. But its not ideal and can stick and Jam the D' slide fully open.
Does anyone else have a PWK, OKO or Keihin carb and can suggest a throttle cable and where to buy one?
P D: SC Chester on Wed Mar 08, 2017 8:55 pm, edited 1 time in total.
P D: SC Chester
by CHRIS in MARGATE » Wed Mar 08, 2017 10:36 pm
You need a small pear shaped cable end and then fit a solderless nipple at headset. I've never had a problem in 10 years getting one.
by P D: SC Chester » Wed Mar 08, 2017 11:34 pm
Thanks Pal
P D: SC Chester
by coaster » Thu Mar 09, 2017 12:53 am
Just a normal PHBH extended cable is all you need, the nipple is exactly the same as a standard carb i.e. very small cylindrical soldered end. I have swapped between phbh and pwk with the same cable
by P D: SC Chester » Thu Mar 09, 2017 8:22 pm
Cheers Coast. I've ordered some but spent an hour of my life I won't get back, filing a a cheese head down!
The must be a Chinese proverb there:
He who can't be arsed in waiting, will spend time faffing!
P D: SC Chester
by coaster » Fri Mar 10, 2017 12:16 am
P D: SC Chester wrote:Cheers Coast. I've ordered some but spent an hour of my life I won't get back, filing a a cheese head down!
All been there and will go there again and again
I've also spent time filing them so that they will go through the angled bend on top of the carb when I have been experimenting with different angles.
Users browsing this forum: No registered users and 9 guests
