you have me worried now... I admit to being a novice and had placed some solder through the plug hole to the side of the head and then measured and it seemed spot on.. what do you see?Fast n Furious wrote:Something not right with that squish band.
yep on strip down found one gudgeon pin wire clip missing so suspect this was the cause of the marksMickYork wrote:The marks on the piston head don't appear to be from pinking. It looks more like physical damage ?
swissdean wrote:you have me worried now... I admit to being a novice and had placed some solder through the plug hole to the side of the head and then measured and it seemed spot on.. what do you see?Fast n Furious wrote:Something not right with that squish band.
