P D: SC Chester wrote:Thanks for the replies.
Firstly it makes no difference if it's hot or cold.
The clutch is a standard and recently furnished with new plates.
It does feel it's something that stops working once the engine idles. But is fine any other time.
holty wrote:i would suspect clutch drag as well, if you have fitted new plates that should rule them out, your springs could be the problem, maybe coilbound before the plates are separated enough, or clutch arm in wrong position maybe ?
