ts1 avanti piston
ts1 avanti piston
Postby Daz-uk » Tue Apr 25, 2017 8:27 am
I have a new TS1 225 barrel and need a piston, was looking at the Avanti TS1 piston, with oval reed valve cut out, are these a direct replacement piston, so just fit correct grade to barrel and its ok, as what difference does the oval cut out make make, or best to use AF piston? Thanks
Daz-uk
Re: ts1 avanti piston
Postby coaster » Tue Apr 25, 2017 9:03 am
I didn't realize that Ron did a reed valve piston or I'd have bought one last year when I reed valved my Avanti TT3. What I did was use a TS1 piston as a pattern to mark and cut windows into the Avanti piston skirt as well as the cut away at the bottom. The windows lined up well with the Avanti inlet so I would image the same would be true in reverse. Also, a single oval window is likely to flow better than 2 windows as per the TS1 I would think.
Postby hullygully » Tue Apr 25, 2017 11:30 am
I've used both in my TS1's with no problems 8-)
some people say it weakens the piston?????????? :shock:
Postby Scooterlam » Tue Apr 25, 2017 8:54 pm
coaster wrote:I didn't realize that Ron did a reed valve piston or I'd have bought one last year when I reed valved my Avanti TT3. What I did was use a TS1 piston as a pattern to mark and cut windows into the Avanti piston skirt as well as the cut away at the bottom. The windows lined up well with the Avanti inlet so I would image the same would be true in reverse. Also, a single oval window is likely to flow better than 2 windows as per the TS1 I would think.
pretty sure Rons ts1 pistons wont fit a reed Avanti,
Scooterlam
Postby Leotech » Wed Apr 26, 2017 8:04 pm
I asked him last week, no they don't fit.
Leotech
Postby ian i.o.w » Wed Apr 26, 2017 8:45 pm
Ron told me his makita pistons will fit a standard ts1 barrel (no tuning)i have just fitted one in my new build ts1
ian i.o.w
Postby gaz_powell » Wed Apr 26, 2017 10:40 pm
So what grade Avanti piston did you use against grade on TS1 barrel?
Postby coaster » Wed Apr 26, 2017 11:51 pm
Ron old me a Makita grade C reed valve piston a few years ago, I wasn't bothered about the grade at the time as it was going to go in a home brewed Indian Ally 225 reed valve set up. I decided not to go that route in the end so bought a C grade TS1 barrel and it fitted perfectly so I would guess the grades are to some sort of set tolerances.
Postby ian i.o.w » Thu Apr 27, 2017 7:07 am
gaz_powell wrote:So what grade Avanti piston did you use against grade on TS1 barrel?
I had a damaged B barrel and had a B piston off Ron sent both to Aptec and got it ceramic lined
ian i.o.w
Postby gaz_powell » Thu Apr 27, 2017 7:56 am
Cheers Ian, I was just looking for a straight replacement in my B barrel.
Postby ian i.o.w » Thu Apr 27, 2017 8:08 am
gaz_powell wrote:Cheers Ian, I was just looking for a straight replacement in my B barrel.
Just been to shed and on the box it came in it said size B 69.98 hope this is useful if not you could ring him
ian i.o.w
Users browsing this forum: No registered users and 9 guests
