by gazztronomic » Sat May 06, 2017 11:09 am
Hi there has anyone changed the disc on a pepperpot hub??? Mine is for drum links so it has the plate for the pin to sit in does this need to come off?? Don't want to start to rive things off and be left with nothing to use all help appreciated
Gaz
gazztronomic
by gaz_powell » Sat May 06, 2017 4:19 pm
To do the job you need the hub removing from the forks, and the caliper carrier from the hub.
There's no need to rive at anything, but some hydraulic hoses are a neat length and that means you need to remove the caliper off the carrier to get enough movement on hub to allow it to be removed from forks.
To get the caliper off the carrier in this case requires the rim to be loose, so caliper will pass - you cannot get the caliper off the carrier with the rim bolted on hub.
Hope this helps
by gazztronomic » Sat May 06, 2017 6:18 pm
Figured out thanks was as simple as taking one bolt off just needed a vice to sort it out cheers
gazztronomic
by gaz_powell » Mon May 08, 2017 7:11 pm
Glad you're sorted
Users browsing this forum: No registered users and 31 guests
