P D: SC Chester wrote:
Mr Tornado, you don't happen to have a pic of the said modified nuts do ya?
jonw wrote:I don't know whether this helps but I've been using K-Nuts for 3 years now and never had any loosening issues.
Old topic herewith: viewtopic.php?f=10&t=1847
P D: SC Chester wrote:I've not found K nuts but, seen some tall brass nuts with drilled our holes and wire. Bit pricey at £12 but, if it means not having to remove foot boards n drop the engine to get the f'in Cowell off, probably worth it!
Warkton Tornado No.1 wrote:jonw wrote:I don't know whether this helps but I've been using K-Nuts for 3 years now and never had any loosening issues.
K-nuts are bl**dy marvelous as previously stated by several of us that have been using them for over 20 years![]()
However, they should be selected to be of the type for elevated temperature in the case of M7, if they truly exist in that size. They certainly are available for other sizes where used, for instance, on race braking disc hubs, but I could never find them @ a reasonable price in M7. Perhaps knowledge about them has increased their use since I last looked in earnest...
[Stockists may charge a massive premium on less common sizes because they may have to pay themselves for an EOQ (Economic Order Quantity) for a batch manufacture] That was the principle reason I adopted cross drilled long nuts [or even cap heads in cast iron/Rapido barrels that can stand it, unlike alloy (threaded) barrels]![]()
Do report back if you find them, though, please
Warkton Tornado No.1 wrote:I stand corrected!Things have indeed moved on regarding high temperature M7 K nuts @ £0.99 each:
https://www.autosport-bearings.co.uk/pr ... 7QodOFUF4A
However, my personal preference remains in using the longer nut options (with lock-wiring) as they give greater peace of mind & are re-usable.
P D: SC Chester wrote:It's all just nuts!
Users browsing this forum: Baidu [Spider] and 16 guests
