time-saving bridge clips available from the LCGB
Postby Sticky » Thu May 25, 2017 8:12 pm
...if you are going to Adria you can pick these up from Toot on the LCGB stall
Sticky
Re: time-saving bridge clips available from the LCGB
Postby dickie » Thu May 25, 2017 8:30 pm
Or if you're not going to go to a rally where the stall is, these work well and no drilling; just push them in.
Sometimes called rawl nuts or alternatively well nuts. Cost pennies.
Postby Warkton Tornado No.1 » Thu May 25, 2017 10:54 pm
I've used Rawl nuts for some time, but recently took them off. I fitted floating anchor nuts as they give the opportunity to use more of the full extent of the slot than the Rawl nuts due to the outside diameter of the rubber.
Rawl nuts will suit some, but if you need the almost full extent of the slot, (as I did) the SLUK items seem a better option to me.
"Horses for courses" eh?
Nice to have a new option, IMHO. :)
Postby grandpa » Fri May 26, 2017 1:00 pm
Hi
Yes,another good idea for the bridge piece problem
You could use a bolt from underneath place a tap washer or anti vibration washer to stop bolt falling out and refit bridge piece with
stainless steel washer and dome headed nut.If bolt head turns a long bladed screw driver can be used to stop bolt turning.
Not for purists
Grandpa
grandpa
Postby Topgearskin » Fri May 26, 2017 3:02 pm
dickie wrote:Or if you're not going to go to a rally where the stall is, these work well and no drilling; just push them in.
what size would you need?
Topgearskin
Postby coaster » Fri May 26, 2017 4:55 pm
Warkton Tornado No.1 wrote:I've used Rawl nuts for some time, but recently took them off. I fitted floating anchor nuts as they give the opportunity to use more of the full extent of the slot than the Rawl nuts due to the outside diameter of the rubber.
Do you mean these WT? http://www.ebay.co.uk/itm/Cage-Nuts-Cag ... AugOCuPFSA
I've just fitted them to my LiS, needed to file the strut holes with a square file a bit but work perfectly.
Postby dickie » Fri May 26, 2017 5:49 pm
That depends on the screws you use but normally m5
Postby Warkton Tornado No.1 » Sat May 27, 2017 11:13 am
I used these with pop-rivets to secure them in place:
Remembering now that I found that M5 Rawl nuts that I have were also a bit big for the slots in my frame so I had to enlarge the slots to a shape like a key hole to accommodate them in what I judged to be the best place.
Postby P D: SC Chester » Sat May 27, 2017 8:49 pm
grandpa wrote:Hi
Not for purists
Grandpa
Like.
P D: SC Chester
Postby Fast n Furious » Sun May 28, 2017 12:27 am
I use stainless M5 caged nuts here. Simply elongate the holes in the cross tree and make them 8.3 mm wide. This then allows the bridge piece to slide into place once you have the screws in place. Less fighting with the rubber gaskets and no burning your hands on a hot exhaust.
