Warkton Tornado No.1 wrote:You're doing nothing wrong but if I were you, I'd try this:
Remove crank & the drive side oil retaining plate.
Refit crank with no shims & test that it turns (it almost certainly will)
Remove crank & with a better understanding of 'all' that the drive side oil retaining plate does, just try that on the loose crank, well greased/oiled on the sealing lip. The seal spring should face the crank & you need to rotate it as you push the drive side oil retaining plate on. It should grip the journal that it runs on but allow you to turn it easily (if that makes sense) Going through this exercise enables you to appreciate how easy it is to invert the seal lip & understand the forces involved, twisting as much as pushing.
Once you 'get' the feel for what's involved, you can look @ any issue like the drive side oil retaining plate being proud of where it should & if it is, be prepared to linish the face for clearance, rather than use a shim.
I hope this long winded explanation helps.
Knowledge wrote:I would try to source a different thickness of Hallite washer rather than machining the retaining plate. The alternative is the new casa retaining plate that uses an O ring instead of a hallite washer.
Fast n Furious wrote:I've never needed to use any such spacers but surely the spacer in question should go behind the bearing not between the bearing and the crank?
Users browsing this forum: Bing [Bot] and 44 guests
