speedometer mod
speedometer mod
Postby monument7 » Mon Jul 31, 2017 11:55 pm
Hi Guys
I am looking to change the speedometer in an S2 headset. I like the look of the standard raised round one or maybe an electronic type with everything on it. It will be hooked up to a CBR 600 motor so any suggestions apart from "give ya heed a shake" would be appreciated.
Machining not a problem so anything that looks sensible i'll look at.
Hope that makes sense.
monument7
Re: speedometer mod
Postby Fast n Furious » Tue Aug 01, 2017 1:45 am
As far as I know there would only be the SIP electronic unit that would drop straight in?
Re: speedometer mod
Postby mickyb » Tue Aug 01, 2017 7:04 am
have a look at Acewell speedos, they do a round one
mickyb
Re: speedometer mod
Postby Tractorman » Tue Aug 01, 2017 8:23 am
Fast n Furious wrote:As far as I know there would only be the SIP electronic unit that would drop straight in?
Agree, good speedo and other info.
Re: speedometer mod
Postby gp200ts1 » Tue Aug 01, 2017 11:01 am
Got an acewell fitted to my series 2. Perfect fit.
gp200ts1
Re: speedometer mod
Postby monument7 » Tue Aug 01, 2017 4:44 pm
Not really worried about the fit its more the function to try to get as much info up top without other guages but then again a few guages can look the part. Think i'm confusing myself now. Smiths style bike speedo ?. Gawd knows but some interesting suggestions thanks which i'll look into.
monument7
Re: speedometer mod
Postby Wack » Tue Aug 01, 2017 7:41 pm
I've been using an Acewell speedo for years and never had a problem,compared to all the posts regarding the SIP ones.This may be the one if using a bike motor http://www.acewell-meter.co.uk/Acewell% ... full&id=18
Re: speedometer mod
Postby monument7 » Tue Aug 01, 2017 10:32 pm
Now that looks the dogs and £50 cheaper than SIP. Cheers mate
monument7
Re: speedometer mod
Postby shane BBoys » Thu Aug 03, 2017 10:17 pm
Please excuse my ignorance to make either of these speedo's work would a battery be required?
Cheers Shane.
shane BBoys
Re: speedometer mod
Postby Fast n Furious » Fri Aug 04, 2017 1:48 am
shane BBoys wrote:Please excuse my ignorance to make either of these speedo's work would a battery be required?
Cheers Shane.
With the Sip... Yes ideally,
Can't comment on the Acewell.
There are lads on here who claim to run them off their AC circuit directly, but this is crude and likely to blow the clock eventually.
When on tickover with your lights on, you are making insufficient voltage to keep the clock alive and so everytime you come off tickover the clock will go through its self test startup which takes a few seconds. That has gotta be annoying .
Re: speedometer mod
Postby MK Monty » Fri Aug 04, 2017 5:35 pm
I have been running an Acewell lookyliky for about 6 years that they used to sell on eBay around 30 quid. I'm sure they are what is now fitted in the Scomadi and other than the fact that the Rev counter could not be changed from 4 stroke to 2 it's been spot on. The Acewell it seems can be changed but they are 130 quid. I wasn't bothered about cutting the back down on mine to fit it in the series 1 headset at the price. It has a small internal battery or it may even be a rom but it holds all the settings no problem. The battery is isolated when the ignition is off. I recently borrowed a road angel to check calibration and its 2mph under at 65. Good enough. I'm am running Full DC so electronic stuff just works. :mrgreen:
MK Monty
Users browsing this forum: Lloydy and 23 guests
