burnside wrote:I always use Super as apparently it is less likely to contain Ethanol. The last time I filled up with standard from a supermarket pump was back in June at the Morrisons at Harwich, all seemed fine until my next re-fuel and the rubber seal in the fuel cap had swelled so much that I couldn't get the cap back on! But as a rule I will always use super if it is available, if not I don't really worry...oh and Rockoil Groundsman which has served me fine for many thousands of miles
a-teamlambretta wrote:if you filled a can with 1ltr 4% mix and drilled a very small hole in the can and timed how long it took to drain and then did the same but at 2% . in theory the 4% would take longer to drain as its thicker (less viscouse). at 4% this then in theory would make you run weak i e less petrol going in ..... just a theory
a-teamlambretta wrote:whats running in ???
Users browsing this forum: Bing [Bot] and 7 guests
