TS1 Frame Clearance
TS1 Frame Clearance
Postby foremanbob » Tue Oct 03, 2017 4:33 pm
Got a TS1, with LTH manifold and packing plate fitted.
Using offset cones.
Engine into frame, and got a gap between manifold and frame.... but only about 1mm
Is this enough?
Li3 with Standard Shock length.
foremanbob
Re: TS1 Frame Clearance
Postby GeorgeS » Tue Oct 03, 2017 5:30 pm
If you've got 1mm when the scooter is on the stand, then I'd say that's fine as the suspension is at is max & that's the nearest that carb will ever get to the frame. Once you compress the suspension the carb will move away from the frame.
GeorgeS
Postby dickie » Tue Oct 03, 2017 7:43 pm
Maybe I'm a fanny but I lift the back end so that there is no weight on the rear wheel to simulate unloading the rear as you come off a lip at speed. If I can pull a bit of paper out then that's enough for me.
Postby Knowledge » Tue Oct 03, 2017 10:41 pm
Try a shorter shock, like a R1. Loads more clearance.
Postby Fast n Furious » Sun Oct 08, 2017 11:13 pm
A bit of fetling to the manifold with a Dremmel will improve your clearances.
Postby foremanbob » Tue Oct 10, 2017 5:18 am
first ride on her... apparently 1mm is enough... not frame contact with manifold (well no paint missing...)
foremanbob
Postby coaster » Tue Oct 10, 2017 7:35 am
foremanbob wrote:first ride on her... apparently 1mm is enough... not frame contact with manifold (well no paint missing...)
You would notice a significant increase in vibration if it was touching
Postby HxPaul » Tue Oct 10, 2017 9:08 am
dickie wrote:Maybe I'm a fanny but I lift the back end so that there is no weight on the rear wheel to simulate unloading the rear as you come off a lip at speed. If I can pull a bit of paper out then that's enough for me.
+1
Users browsing this forum: No registered users and 3 guests
