Warkton Tornado No.1 wrote:If you intend to salvage the hub, beware of drilling deeper, but you could repair the holes.
As M7 is just a slightly bigger version of common M6 x 1.0, you can usually Helicoil a stripped M7 'down' to M6 with a kit.
It might sound a bit crazy but was something I've done in the past when I couldn't acquire any quality high tensile fasteners elsewhere on a Lambretta.
With any rear hub extraction, though, you should fit the longest, good quality fasteners that will fit almost the full depth of the hole without bottoming out that ensure the extractor tool is clamped into place, tighten the centre bolt & give it a knock with a hammer.
I hope that helps.
EddieStone wrote:Warkton Tornado No.1 wrote:If you intend to salvage the hub, beware of drilling deeper, but you could repair the holes.
I hope that helps.
Did this and it worked a treat.
Thanks!
EddieStone wrote:Turns out the endplate was loose. Didn't have to take the hub off after all.![]()
I've never had this ever before. Any idea what causes it and how to prevent it? Apart from doing the nuts up tight, of course
Users browsing this forum: Google [Bot] and 10 guests
