Best paint prep
Best paint prep
Postby swissdean » Mon Oct 23, 2017 2:46 pm
I am an impatient sod, friends here have guided me to go for chemical striping of my '66 S3 frame and panelwork prior to painting.
I've seen the results and they look impressive (so they should for close to 800 quid! - swiss prices)..however I can't get bits in until pre xmas which means wont be painted until after..and id really like to re assemble over the xmas break.
So thinking about the old fashioned way of wet and dry and sanders etc in the garage ...it will take me a couple of days I would think but what do others normally do. I've stripped back what looked like great paint to find masses of filler on the legshield and some pin holes already...so almost on the page of ditching and buying remade leg shields vs fixing up, anyone had experience with these
Thoughts and experience welcome
Dean
swissdean
Re: Best paint prep
Postby grandpa » Tue Oct 24, 2017 8:58 am
Hi Swissdean,
I wish some adults would answer this, soon I will also be stripping a scoot for painting.I have used a brass wire brush in a drill to successfully remove paint from some wheel rims and a petrol tank recently and was considering using polycarbide wheels in a drill .Still have marks on my hand from using chemicals on past projects.
Does anyone have any experience of using polycarbide wheels?
Grandpa
grandpa
Re: Best paint prep
Postby coaster » Tue Oct 24, 2017 3:14 pm
I stripped my 67 LiS using a combination of Nitromors (next to useless), angle grinder with Wire brush attachment, flap wheels and sanding disc. I did the whole scooter, it took me HOURS and I still ended up finishing off with wet & dry in places. Also, the inside of the rear loop and most of the main tube under the loop were impossible to fully strip. My side panels had a few dents and dings as did the leggies which also had a large rust hole to deal with hence plenty of new filler and more filling :roll:
I had my Jet grit blasted and although it still needed going over with emery to remove the grit that gets embedded in the surface but all told, a LOT less bother than doing it by hand. 8-)
Re: Best paint prep
Postby steve t » Tue Oct 24, 2017 7:32 pm
Had my series 3 chemically stripped fantastic job and I didn't even break a sweat can't recommend enuff great finish and it causes no more damage as blasting some times does
steve t
Re: Best paint prep
Postby swissdean » Tue Oct 24, 2017 9:29 pm
Thanks all, patience it is then with chemical stripping to follow
swissdean
Re: Best paint prep
Postby SlackerThePinstriper » Wed Oct 25, 2017 1:08 pm
coaster wrote:I stripped my 67 LiS using a combination of Nitromors (next to useless), angle grinder with Wire brush attachment, flap wheels and sanding disc. I did the whole scooter, it took me HOURS and I still ended up finishing off with wet & dry in places. Also, the inside of the rear loop and most of the main tube under the loop were impossible to fully strip. My side panels had a few dents and dings as did the leggies which also had a large rust hole to deal with hence plenty of new filler and more filling :roll:
Nitromors is better to use heated up if possible.
They have took all the decent stuff out of it now due to health and safety etc
Re: Best paint prep
Postby mr mugello » Wed Oct 25, 2017 5:50 pm
You can get the more powerful from car trade paint suppliers here in the UK. Horrible stuff. Highly toxic fumes. Done a couple of scooters with it, but never again.
mr mugello
Users browsing this forum: Baidu [Spider] and 12 guests
