Hammer RB230 wrote:So how long do you run in a new nicasil barrel and piston ? I been told to run in my new RT195 for 500 miles !
missing lynx wrote:as above I thought it was to remove any blemishes and unevenness in the bore and bed in the rings one thing I would say If you buy a kit and the recommendation is say run in for 400 miles and you don't and seize it (possibly terminal with nikasil ) you will have no come back with the supplier
Scooterlam wrote:So running in a cast barrel is basically using your piston rings to wear out any imperfections.
Is there no machining process to do this
HxPaul wrote:How come you dont need to run in a modern car ?
missing lynx wrote:because it's 4 stroke and watercooled
Users browsing this forum: Google [Bot] and 18 guests
