by davla » Fri Nov 10, 2017 5:22 pm
Is there an easy way of replacing the inner & outer throttle cable, the type with the soldered nipple?
davla
by St George » Fri Nov 10, 2017 6:31 pm
It depends if the old outer cable has been cable tied to the frame. You will have to get on your hands and knees and fiddle with the new one. A small mirror and a torch may help. Try to pull the old one out from the bottom or top but cut the nipple off first, hope this helps.
St George
by CHRIS in MARGATE » Sat Nov 11, 2017 11:08 am
Pull the inner out of the new. Push the new outer over as much of the existing inner cable as possible. Tape it up where the 2 outers butt up. Smooth the join.
Down under the scooter check for straps or ties and loosen or cut as necessary.
Gently pull the old and push the new until all the way through.
Unbind and push the inner through.
Now you have to push the outer at the headset end into place and this is.best done by tensioning the inner.
Est time: 15 mins - 3 hours !!!
by coaster » Sat Nov 11, 2017 11:21 am
CHRIS in MARGATE wrote:................Est time: 15 mins - 3 hours !!!
There speaks the voice of experience
by burnside » Mon Nov 13, 2017 1:28 pm
CHRIS in MARGATE wrote:Pull the inner out of the new. Push the new outer over as much of the existing inner cable as possible. Tape it up where the 2 outers butt up. Smooth the join.
Did exactly that when I changed one of mine last year, took about 15 mins
burnside
by davla » Mon Nov 13, 2017 3:26 pm
Yeah but you can’t take the inner cable out of the new cable as it’s got a soldered on nipple
davla
by rossclark » Tue Nov 14, 2017 3:50 pm
CHRIS in MARGATE wrote:You cut one off and replace with solderless nipple.
If you do that to one of the fixed length ones with a nipple at either end won't it then be too short?
by CHRIS in MARGATE » Tue Nov 14, 2017 4:19 pm
Put a new inner in. Tuppence halfpenny.
Solutions to Problems not Problems to Solutions.
by burnside » Wed Nov 15, 2017 10:24 am
davla wrote:Yeah but you can’t take the inner cable out of the new cable as it’s got a soldered on nipple
I don't think I've ever had one with a soldered nipple at both ends, only ever at one end, always nice to have some adjustment
burnside
by HxPaul » Wed Nov 15, 2017 11:21 am
burnside wrote:davla wrote:Yeah but you can’t take the inner cable out of the new cable as it’s got a soldered on nipple
https://www.ebay.co.uk/itm/lambretta-th ... SwImRYjw-Q
by burnside » Wed Nov 15, 2017 10:40 pm
HxPaul wrote:burnside wrote:davla wrote:Yeah but you can’t take the inner cable out of the new cable as it’s got a soldered on nipple
Wasn't saying you don't get them, just that I've never ordered one, but all mine need an extra long cable which is probably why
burnside
Users browsing this forum: Bing [Bot] and 16 guests
