Lost me ignition key!
Postby EddieStone » Mon Nov 20, 2017 7:24 pm
Scoot's at work, and I'v lost me flipping key.
It's an '87 Indian GP150, what options are there?
(please don't mention a spare. I doubt there ever was one!)
EddieStone
Re: Lost me ignition key!
Postby dickie » Mon Nov 20, 2017 7:31 pm
Pull the green wire off the cdi.
It'll get you home. Then stall it or kill the engine with the choke.
Postby Knowledge » Mon Nov 20, 2017 9:59 pm
Will an ‘87 Bretta have a CDI from which you could pull the green wire?
Maybe
Postby Adam_Winstone » Mon Nov 20, 2017 11:13 pm
^... Martin, are you suggesting that there might still be an 87 SIL GP with reliable factory points setup?! :lol:
Postby EddieStone » Mon Nov 20, 2017 11:43 pm
Adam_Winstone wrote:^... Martin, are you suggesting that there might still be an 87 SIL GP with reliable factory points setup?! :lol:
Ahem. Yes it is an 87 SIL GP with reliable factory points set up. I ride it to work everyday.
I pull the green wire out of the contact block don't I?
Trouble is when I ride it home, it's dark and I need the lights (which also work reliably on an 87 SIL GP....!)
EddieStone
Postby dickie » Tue Nov 21, 2017 5:13 am
The green wire doesn't affect the lighting circuit. It's only used to ground the LT supply and kill ignition. If it's the usual green wire anyway.
Postby EddieStone » Tue Nov 21, 2017 10:26 am
Any recommendations of somewhere to get a replacement barrel?
It's a points AC. Sort of 12V, I think.
EddieStone
Postby Adam_Winstone » Tue Nov 21, 2017 9:24 pm
Eddie,
I'm glad, and impressed, to hear it. I'm a big fan of SIL stuff and actually a fan of any reliable ignition, whether it be points or electronic, total loss, whatever.
Before Euro Lambretta Ireland (Millstreet) I swapped out my 6V electronic system for 12V DC points + battery as I wanted better lights. Everybody thought me mad but the bike didn't miss a beat :)
Good luck sorting the key issue.
Adam
Postby EddieStone » Tue Nov 21, 2017 10:55 pm
Cheers Adam. I checked with Jem Booth, Lambretta key master, and he identified the lock as an aftermarket one, so I've bought a replacement rather than mess about trying to find a key.
I fitted electronic ignition to my Li and it made a fantastic difference. I'm planning electronic for the GP, but thinks like getting it re-bored and fitting ignition locks keep getting in the way!
What I am impressed by is the lights. It seems to be 12V ac lights and points. Or at least 12V lights.
EddieStone
Users browsing this forum: Bing [Bot], Google [Bot] and 14 guests
