Solid Air wrote:Is it a misfire or poor engine response at speed? Are you running an air filter?
Mark
Solid Air wrote:I'm no expert and there's some really knowledgeable people on here Celt but as it looks like you've already covered a lot of things, I'm wondering did the fault develop on its own or had you changed something or maybe rebuilt the engine?
St George wrote:Try putting the choke on in 4th when it starts playing up. worked for me years ago on one of my old bikes. Indication of lack of fuel combined with resistance. Fingers crossed.
dickie wrote:I had the same symptoms recently and i could only put it down to fuel starvation but all the usual checks were ok.
Mine turned out to be a carb problem. I'm not saying yours is, but when you say you changed the carb, did you change it completely or did you leave the float bowl for example? (Forgive my ignorance of mikuni carbs).
Dazts1 wrote:I once had the same kind of problem on a ts. I did all the things you've changed rode half the season really struggling with the scoot. I got back from brid the last rally and pulled the bike apart. Normally I would take my pipe off in one piece. But as it wasn't going back on I split the pipe down into pieces. Removing the rear muffler section only to find a blockage in the pipe. It was a Taffy mk4. Like I say up until that point I'd been removing the pipe in one piece. After phoning a couple of the lads to tell them ov my joy of finding the problem. I was told if you ever took the bike to AF one of the 1st things ray used to do was rod the pipeeven thinking about it it seemed electrical the problem. I'm surprised the bike ran , it never holed the piston as the heat build up must have been immense.
Anyway something for you to check. Good luck.
