Lads
I wanna rebuild a crank for TS1 motor
want it with a good strong 110mm rod with a top quality big end bearing
So what’s best to go for & who to buy from?
Ever considered a Vespa Ape rod?
110 mm x 18 mm
Norrie Bodge wrote:Lads
corrado wrote:I've had several SIL GP200 cranks re-rodded by the same people that Paul "storkfoot" uses, Grampian in Liverpool I presume.
I've had the 110 Yam rods that fit without shims or the Kawasaki [slimmer rod and bearing] that fits with shims. Grampian can't understand why we'd want shims when most motorbikes don't need them. Probably had at least 6 of each and never had an issue with any of them. They specialise in cranks and pistons so they know a bit.
As mentioned though AF, Harry Barlow & Darrel Taylor to name a few will all build you a quality crank.
Or bite the bullet and buy a Casa one for @ £400
Users browsing this forum: Google [Bot] and 5 guests
