Clutch basket Help
Clutch basket Help
Postby compass » Wed Jan 24, 2018 8:09 am
Went to replace my clutch for a 5 plate, what seemed a simple quick job ! :roll:
However my basket is steadfastly STUCK! Have tried heat and gentle tapping, had a second opinion last night and both concluded ITS STUCK lol. The only difference is that it is on the 5 speed box, so assuming the splines are ultra tight?
Any tips, ideas, anyone else had same trouble?
Thanks in advance
Compass
compass
Re: Clutch basket Help
Postby modster79 » Wed Jan 24, 2018 8:36 am
I had the same problem on my cyclone, for once I had some patience and kept tapping spline down and using a long lever under the basket moving around as I continued to tap spline. It came in the end.
modster79
Postby Covboy » Wed Jan 24, 2018 10:29 am
Friend had a similar issue - his new cyclone cluster would not fit any basket . He sent it back to the dealer and they replaced or remachined it. The replacement was perfect
Postby HxPaul » Wed Jan 24, 2018 10:43 am
Have you tried a puller ?
Postby compass » Wed Jan 24, 2018 10:56 am
Not got a puller. I will try the patience thing tonight (tapping and levering) , I soaked in WD40 last night that may help?
compass
Postby compass » Thu Jan 25, 2018 6:51 pm
Tried heat, left to soak in WD40 over night, tapping and levering with patience until lever slipped and cut thumb open on casing stud, then tried with less patience.
It ain't moving :cry:
Would a puller help, not used one before ?
compass
Postby Triffid » Thu Jan 25, 2018 6:55 pm
I use a 3 legged puller - Machine Mart do them. With a bit of jigging around I've always managed to get the clutch spider off using one :D
Triffid
Postby hullygully » Thu Jan 25, 2018 7:17 pm
I've had a puller manufactured, just uses the plates retaining spring to hold in place, with bolt in middle to screw down onto xmas tree :shock:
where in country are you?
Postby compass » Thu Jan 25, 2018 8:17 pm
I think Paris is closer to me :lol:
I'm in sunny Hastings 8-)
compass
Postby compass » Thu Jan 25, 2018 8:33 pm
Will try the puller from Machine Mart, was it the 4 inch. :?:
compass
