timing
timing
Postby rexton270s » Sat Sep 06, 2014 10:51 am
hi any idea of a starting point for the timing on my avanti with varietronic ignition, before i put in on a strobe light?? :?:
rexton270s
Re: timing
Postby Knowledge » Sat Sep 06, 2014 5:44 pm
Are you concerned about damaging the engine by starting with the stator in a "non-ideal" position?
I have never set-up a varitronic system, but I would start with the stator screws in the middle of the slots. It is hard to imagine that you can do any harm by starting from here and strobing it before making fine adjustments.
Re: timing
Postby steeleyscoot » Mon Sep 08, 2014 10:55 pm
+ 1
steeleyscoot
Re: timing
Postby corrado » Wed Sep 10, 2014 11:27 pm
I set mine at 20 degrees at tick-over, should give me around 14 degrees at 6,000 rpm. Asuming I've read the blurb correctly.
corrado
Re: timing
Postby Wack » Thu Sep 11, 2014 10:11 pm
Why?
