Hi everyone
I have Lambretta S3 150 with electronic ignition and dellorto 18 carb. Problem is this- it starts up fine but dies after 30-40 seconds. I have by passed the tank - still the same. Changed float, red tipped valve, hinge and bowl. I have sanded the inside of the bowl and the outside of the float - still the same. It's just like the carb is filling up then the valve is sticking in the up position and when it's used the fuel in the carb it cuts out, leave it for a minute and kicks up again. Could I be barking up the wrong tree and could it be electrical.
Any comments appreciated.
Thanks in anticipation.
Paul
