by davla » Thu Mar 22, 2018 10:34 am
I'm going to rebuild/upgrade a Series 1/2 engine and was wondering if there's any point/benefit in changing the drive sprocket spring to the longer Series 3/GP spring and cap/washer?
davla
by ULC Soulagent » Thu Mar 22, 2018 1:37 pm
No harm in upgrading I’d suppose
ULC Soulagent
by Fast n Furious » Thu Mar 22, 2018 10:31 pm
What is to be gained?
by davla » Thu Mar 22, 2018 10:36 pm
That's my point but they must have changed it for a reason...
davla
by petemaisey » Fri Mar 23, 2018 6:07 pm
If you upgrade the spring you will also need a deeper side case. The spring was changed due to being not strong enough.
The sprung clutch centre also was eventually changed to a solid type due to frequent failure.
The early flywheels also had to be revised because the alloy fan was fixed to the brass centre by roll pins around the circumference. These of course came outwards under centrifugal force and dug into the flywheel housing. This gave the impression of a seized solid motor.
petemaisey
by HxPaul » Fri Mar 23, 2018 7:38 pm
petemaisey wrote:If you upgrade the spring you will also need a deeper side case. The spring was changed due to being not strong enough.
Why is this.I thought the sleeve and spring cap were the same length on early and late models.
by Wack » Wed Mar 28, 2018 5:43 pm
The Ser 1 spring cap is shallower to go with the shorter spring.
by HxPaul » Wed Mar 28, 2018 6:40 pm
If the series 1 spring cap is shorter then it would sit deeper in the crankcase,each side case is the the same depth.I have just built one with a sidecase that has 6mm holes for the exhaust studs,this uses a series 3 crankcase with a series 3 sleeve and spring cap.
