SIP speedo problem
SIP speedo problem
Postby Tractorman » Sun Apr 08, 2018 3:10 pm
Coming back from the VMSC rally the SIP speedo froze so I pressed the programme change button and went ok for a while then it went haywire. It change from one programme to another, at first I though it must be water got into the button but then noticed it also zeroed the distances on A & B. Finally it all went to zero with occasional flashes of speed and distance. I've not looked into anything yet but wondered if anyone has had a similar fault.
Re: SIP speedo problem
Postby Covboy » Sun Apr 08, 2018 3:21 pm
Hi -sounds like the selector button is stuck in - try disconnecting it - i had to take my button apart (peel back the rubber cover) and araldite the contacts as they had come off the mini PCB. works fine now.
