rapido 240, reed, boost ports, PHBH 30
Postby lofty » Fri Apr 27, 2018 12:54 pm
hi all, I'm after suggestions/starting points for
rapido barrel
LTH reed
Boost ports
71mm wiseco H2 piston (reed holes cut)
60 stroke
115mm con rod
I have a PHBH 30mm and I'm looking for carb setup suggestions..
thanks
lofty
Re: rapido 240, reed, boost ports, PHBH 30
Postby Norrie Bodge » Sat Apr 28, 2018 8:24 am
lofty wrote:hi all, I'm after suggestions/starting points for
rapido barrel
LTH reed
Boost ports
60 stroke
115mm con rod
thanks
try this for starters m8
Needle float = 300
Pilot = 53
Slide = 40
Needle = x13 on 2nd clip from top
Atomiser = AV266
Main = 138
Norrie Bodge
Postby dscscotty » Sat Apr 28, 2018 11:51 am
What pipe?
Postby lofty » Sat Apr 28, 2018 5:21 pm
Thanks for replies..
It has a Scootrs - pm style pipe
lofty
Return to Carburettors
