coaster wrote:That's 4.6 gearingmy TS1 also with a 30 PHBH and a JL3 wouldn't pull 4.8
I dropped to something like 5.9 before it became a pleasant ride.
Norrie Bodge wrote:coaster wrote:That's 4.6 gearingmy TS1 also with a 30 PHBH and a JL3 wouldn't pull 4.8
5.9 ?
I run 21x46 on TS230 32VHSA & JL3
Pulls great
That’s with a 2.5mm packer & thick head gasket to give a 1.2mm squish
coaster wrote:Norrie Bodge wrote:coaster wrote:That's 4.6 gearingmy TS1 also with a 30 PHBH and a JL3 wouldn't pull 4.8
5.9 ?
Pulls great
That = a torquey tune, mine did have a 110 rod and a packer to compensate but the port timings were close to standard it was still fairly peaky. On a 1000 mile trip round Germany with Storkoot on his standard Rally 200 I was hard pressed to stay with him on hills. I spent most of the time in 3rd. Got home and dropped the gearing and it was great after that.
Adam_Winstone wrote:
4.7-4.9 is the range that I would be looking to use... but this suits my requirement and riding style. Each to their own.
Adam
jonno wrote:Changing the subject slightly.It pulled lovely right from low revs in 3rd.I did a plug chop today,rich at 30,but grey at 50 on these settings.53 idle , av268 attomiser x7 needle 2nd clip down 138 main 70 choke and a 350 needle valve.Two turns out on idle screw. Any richening and it wont pull away and bogs down terribly.Why such a difference between 30 and 50?
Rich Oswald wrote:jonno wrote:Changing the subject slightly.It pulled lovely right from low revs in 3rd.I did a plug chop today,rich at 30,but grey at 50 on these settings.53 idle , av268 attomiser x7 needle 2nd clip down 138 main 70 choke and a 350 needle valve.Two turns out on idle screw. Any richening and it wont pull away and bogs down terribly.Why such a difference between 30 and 50?
If it's weak in mid range go down a clip on the needle or if that doesn't work, which I suspect it won't, then go to an X13 needle, that shouldn't in theory affect you pulling away.
jonno wrote:Would a box exhaust help,slowing things down? MB etc,or wouldnt it make much difference?
jonno wrote:I was going to ask if the lean spot was down to the port positions,but if youve had yours tuned grim I wouldve thought that would have solved the problem. Anyone know why the TS1 has this trait?
Users browsing this forum: No registered users and 18 guests
