Early li 125 gearbox on a ts1 ?
Postby al pushpak » Sun Jun 10, 2018 9:48 pm
Hi, just wondered is anyone is running one of these boxes on ts 225 with a bgm clubman exhaust & also what sprocket set up do you have ? thanks for any info ;)
al pushpak
Re: Early li 125 gearbox on a ts1 ?
Postby Norrie Bodge » Sun Jun 10, 2018 10:42 pm
I’d av thought 18x47 = 4.8 be best
Norrie Bodge
Postby soullad » Mon Jun 11, 2018 8:55 am
Yep, great box
Easier clutch life with bigger front sprocket, as per the 4.8 set up above
Great ratio in 1st esp if 2 up, luggage etc
Often unworn & cheap
Don’t tell everyone thou ;)
soullad
Postby lozmondo » Tue Jun 12, 2018 5:13 pm
Agreed.
I run 2 of them. 1 on a very revvy TS1 with a 16 tooth and the other on an RT195 with a 17.
Cost less than a third of what you pay for an LI150 box
lozmondo
Postby al pushpak » Thu Jun 14, 2018 9:37 am
thanks for your replies ;) what sprockets would you recommend for this gearbox ?full frame series 1, ts225, 30mm dellorto & bgm clubman & a 12 stone rider ! :) thanks again ;)
al pushpak
Postby soullad » Thu Jun 14, 2018 3:40 pm
18 x 47 would be a good starting point.
soullad
Postby al pushpak » Sat Jun 16, 2018 6:26 pm
Hi, guys, quick update , fitted the li 125 box today ,tried the 18x47 combo pulled great uphill but seem to run out of steam on the flat, put 17 X 46 combo on , much better ;) thanks again for your advice ;)
al pushpak
