Test of Stator
Test of Stator
Postby Norfolk » Sun Jul 29, 2018 9:09 am
Can anyone please tell me what reading or how I can test a Varitronic stator, engine keeps wanting to cut out until it gets warm then runs like a dream.
The CDi unit has been replaced which at least allowed the engine to start.
Apart from removing the resin over the wires to the stator every wire has now been soldered and earth wires are running all over the place.
Thanks in advance
Norfolk
Re: Test of Stator
Postby MickYork » Sun Jul 29, 2018 11:36 am
Probably best to give Cam Lam a ring, the Varitronic has different readings to other stators.
Re: Test of Stator
Postby coaster » Sun Jul 29, 2018 11:31 pm
What makes you think its electrical? your symptoms would suggest that its running a bit weak. Have you checked for an air leak?
Re: Test of Stator
Postby Norfolk » Mon Jul 30, 2018 9:02 am
Ok coaster for that, I will give it a try
Norfolk
Re: Test of Stator
Postby coaster » Mon Jul 30, 2018 12:55 pm
Norfolk wrote:Ok coaster for that, I will give it a try
Try putting the choke on when its cutting out and see if that improves it.
Users browsing this forum: Bing [Bot], Google [Bot] and 17 guests
