Jetting spec
Jetting spec
Postby Cgt75b » Wed Aug 01, 2018 4:57 pm
Hi folks, after ball park jetting spec for a Mugello 186 running a 28 mil dellorto open mouthed 48 mil clubman.
Thanks for any help.
Re: Jetting spec
Postby Scooterdude » Wed Aug 01, 2018 6:11 pm
There is some useful info in the cam lam site mate
Scooterdude
Re: Jetting spec
Postby Cgt75b » Fri Aug 17, 2018 8:50 am
Thanks scooter dude I'm well aware of there jetting chart pal, Ideally I was after some expertise off this forum, seems a tad thin on the ground though :shock:
Cheers cgt75b
Re: Jetting spec
Postby Scooterdude » Fri Aug 17, 2018 10:17 am
Ok mate. One i built last year : PHBH 28, 300 float valve, 70 choke, 55 pilot, 118 main. AV266 atomiser x7 needle second from bottom clip.
Regards the cam lam site, i struggle to see how they can make the x2 needle work on a lot of those specs, just seems wildly far to rich.
Scooterdude
Re: Jetting spec
Postby Rich Oswald » Fri Aug 17, 2018 10:48 am
Scooterdude wrote:Ok mate. One i built last year : PHBH 28, 300 float valve, 70 choke, 55 pilot, 118 main. AV266 atomiser x7 needle second from bottom clip.
I would agree with all this apart from pilot which I think is way too big. Probably start at 50 and maybe come down to 48. MUST do plug chops though at all throttle openings to be sure.
Re: Jetting spec
Postby Scooterdude » Fri Aug 17, 2018 1:18 pm
Yes lots of plug chops done, which is how we arrived at a 55 pilot, of course every build is different so yes you may well find a 48 or 50 suits yours better.
Scooterdude
Return to Carburettors
