by AdiD63 » Fri Aug 31, 2018 5:28 pm
Struggling to be to find a recommended 6V 15/3W rear light bulb on the internet (UK) for a DL125, 6V AC non battery scooter. Could I use a bulb with a slightly higher wattage rating of 15/5W (Serveta Li 125 AC non battery) ?
Many thanks Adi.
AdiD63
by rossclark » Fri Aug 31, 2018 6:11 pm
Should be fine.
by Fast n Furious » Fri Aug 31, 2018 11:21 pm
BA15d 6v 15/3 watt bulbs were usually found on continental bikes.
British registered machines were fitted with 21/5 watt bulbs to meet UK vehicle lighting regs.
The 15/3 watt bulbs are readily available from continental dealers but there's no advantage to fitting them.
by Storkfoot » Fri Aug 31, 2018 11:54 pm
I’m no electrician but years ago I had a standard S3 Li150. It was 4 pole. I think it had a battery. Without the correct spec 15/3 tail light bulb, I had all sorts of issues. With the correct bulb, all was good.
At the time, Scooter Restorations stocked them but I don’t think they do now.
by Danbretta » Sun Sep 02, 2018 6:15 pm
Lucas might be bringing them back on the market through a vintage supplier the last I heard. Whether this still happens I don't know. Depends on demand I suppose. I forget the name of the contact I spoke to but if you contact them they,'ll get back to you straight away. (If you're that bothered that is
Danbretta
by TurboTrev » Mon Sep 03, 2018 4:28 pm
Scootopia have 6v 18/3w in stock.
TurboTrev
Users browsing this forum: Adam_Winstone and 11 guests
