Jack
Jack
Postby jonno » Wed Oct 10, 2018 7:08 pm
Any ideas for a rear wheel jack,now ive fitted a bgm box, and the jack point is obstructed?
jonno
Re: Jack
Postby Storkfoot » Wed Oct 10, 2018 7:20 pm
Can you not just put it in from the back?
I am presuming it is the standard Lambretta stand you are referring to.
Re: Jack
Postby HxPaul » Wed Oct 10, 2018 7:25 pm
The standard jack stand should fit.Page 206 of "the complete spanners manual"second edition.
Re: Jack
Postby Solid Air » Wed Oct 10, 2018 8:04 pm
Storkfoot wrote:Can you not just put it in from the back?
I havee a BGM Clubman and the Jack does fit in from the wheel side.
Re: Jack
Postby Tractorman » Wed Oct 10, 2018 10:03 pm
If you cut the curved bit off and re-weld the opposite way it will work from the back.
Re: Jack
Postby HxPaul » Thu Oct 11, 2018 8:28 am
Theres no need to cut any part.I insert mine from the wheel side and it works ok.
Re: Jack
Postby jonno » Thu Oct 11, 2018 9:31 am
Thanks never thought it would go in from the back.Will try it.
jonno
Users browsing this forum: No registered users and 15 guests
