Ld wiring help
Ld wiring help
Postby steveg » Fri Jan 04, 2019 7:21 pm
Got this me email- can anyone help?
Hi Steve,
I am restoring a LD150 series III I believe is a USA version. I am
looking for a wiring diagram for it . It has a Bullet type tail light
with brake light. and a resistor on the terminal block on the front
tube. The original harness has a pink wire. The new harness I have has a
Brown and dark blue wire at the brake light switch and 3 wires ,Black,
brown ,green, to the terminal block. It is an AC machine with out
battery. I have got two different wire harness from suppliers the
above one and a battery one. I have a diagram for the one with the pink
wire but not the with out.
Any help you can give would be appreciated.
Don Johnson
steveg
Re: Ld wiring help
Postby jbcollier » Sat Jan 05, 2019 3:20 am
Do you have a pilot/park light as well as the twin-filament, headlight bulb in the headlight bucket?
jbcollier
Re: Ld wiring help
Postby steveg » Sat Jan 05, 2019 11:01 am
jbcollier wrote:Do you have a pilot/park light as well as the twin-filament, headlight bulb in the headlight bucket?
Hi
I posted on behalf of a guy in Canada so don't know anymore.
If you're able to help would you mind e-mailing directly his address is realdjohnson@gmail.com
steveg
Re: Ld wiring help
Postby jbcollier » Tue Jan 08, 2019 3:37 pm
I contacted him directly and all he wants is a wiring diagram that matches what he has: US special with no park light and a resistor in thew headlight bucket. He has a parts book which shows the resistor. Can't help him myself. Anyone out there have the requisite diagram?
jbcollier
Re: Ld wiring help
Postby steveg » Tue Jan 08, 2019 7:21 pm
jbcollier wrote:I contacted him directly and all he wants is a wiring diagram that matches what he has: US special with no park light and a resistor in thew headlight bucket. He has a parts book which shows the resistor. Can't help him myself. Anyone out there have the requisite diagram?
Thanks for getting in touch
steveg
Re: Ld wiring help
Postby jbcollier » Thu Jan 10, 2019 4:40 am
Finally found this:
http://www.newtoyouhomes.com/jbsitefold ... nction.jpg
... though it's not complete. Will pass it on.
jbcollier
Return to Pre 57
