derbystu wrote:Hi All - Not sure if this is going in the right section but I've Got a SIL GP200 problem I'm struggling to resolve. It starts and runs ok for 3 or 4 miles then suddenly starts to splutter and won't rev but continues to tickover. I Limp home on slightly more than tickover (max speed about 10 to 15mph) - leave it for about an hour - starts ok and all seems normal again - but after the 3 or 4 mile run the cycle starts all over again.
I have very little mechanical knowledge/skills but on local suppliers advice have so far tried - a new spark plug, a new air filter, a new coil and finally a new carb (replaced the standard Jetex with a similar Scootopia one, which is about the limit of my skill set!) all without success. Not sure what to try next - grateful for any thoughts/suggestions.
HxPaul wrote:I have a readspeed Lukas CDI that I bought in Dec. of 2017.I use an Anthony Tambs external pick-up and I run the CDI from the lighting coils on the regulator,thus cutting out the need for an LT coil on the stator plate.It works ok and if for any reason the external pick-up packs up working I can switch to the LT coil on the stator plate.
Users browsing this forum: Bing [Bot] and 21 guests
