kick start pedal
kick start pedal
Postby WOO » Wed Feb 13, 2019 6:25 pm
I am trying to fit an sx200 spaq pedal to a series 2 LI to get more leverage
the stop flange on the pedal is too long to connect with the bump stop, it fouls the crankcase.
Its brand new and chrome any ideas other than a hacksaw please
WOO
Re: kick start pedal
Postby gp200ts1 » Wed Feb 13, 2019 7:36 pm
Unfortunately the best thing is a grinder or hacksaw
gp200ts1
Postby ToBoldlyGo » Wed Feb 13, 2019 8:23 pm
Going to need bending. A S3 pedal won't work on a S2. Not sure why you thought it would work.
ToBoldlyGo
Postby HxPaul » Thu Feb 14, 2019 1:16 am
WOO wrote:I am trying to fit an sx200 spaq pedal to a series 2 LI to get more leverage
Surely a series 3 kickstart pedal would hit the rear floorboard on a series 2.
Postby Norrie Bodge » Fri Feb 15, 2019 12:17 am
Norrie Bodge
Postby peejay » Fri Feb 15, 2019 7:34 pm
hi woo
i highly rate the Spaq SX 200 pedal for S2 use.
you do have to cut the end off the stop flange (probably at least 15mm, measure twice and cut once :) )
i clamped mine in a large vice near to the stop flange and bent the pedal outwards using a 3ft length of alloy scaffold pipe.
all the chrome plate remained (bonus)
this of course will put the end of the pedal at an angle, just cut it off and weld it back on square, no one will notice what's been done and you have the satisfaction of knowing that the pedal wont bend out of shape, simples.
Postby WOO » Mon Feb 18, 2019 8:16 pm
Hi Peejay
Wise words, thanks very much I will try what you advised
cheers
woo
WOO
Postby Andyf » Mon Feb 18, 2019 10:02 pm
If fabbing's your thing, couldn't one weld a short section into the end section of a standard series 2 kickstart?
Andyf
Users browsing this forum: Bing [Bot] and 19 guests
