Clutch flange
Clutch flange
Postby Jim » Sat Feb 23, 2019 5:55 pm
I've bought an early li/sx clutch flange (pressure plate) by mistake, can I cut away the bar underneath , to convert to a later one
Jim
Re: Clutch flange
Postby Scooterdude » Sat Feb 23, 2019 9:18 pm
Yes. Just chop it off, although the pin is hardened so you won’t be able to use a hack saw. I used a die grinder to do the one i recently did. Good luck.
Scooterdude
Re: Clutch flange
Postby Jim » Sun Feb 24, 2019 2:20 pm
Scooterdude wrote:Yes. Just chop it off, although the pin is hardened so you won’t be able to use a hack saw. I used a die grinder to do the one i recently did. Good luck.
Just double checking i mean the stem underneath so it turns it into a later li one, not the top pin
Jim
Re: Clutch flange
Postby Scooterdude » Sun Feb 24, 2019 3:01 pm
Yes the stem not the top pin with the thimble.
Scooterdude
Re: Clutch flange
Postby Jim » Sun Feb 24, 2019 3:29 pm
Brill thanks for this, that's my Sunday planned !!
Jim
Users browsing this forum: Bing [Bot] and 20 guests
