Slow speed judder
Slow speed judder
Postby Jim » Sun Feb 09, 2020 4:30 pm
I've got a judder in the steering when slowing down or pulling away. It's a new engine which I've fitted, just checked internals all soid. The only other thing I've done is tighten up the leg shields, any ideas folks?
Cheers Jim
Jim
Re: Slow speed judder
Postby missing lynx » Sun Feb 09, 2020 4:52 pm
Check your forks aren't loose
Postby ULC Soulagent » Sun Feb 09, 2020 5:28 pm
missing lynx wrote:Check your forks aren't loose
+1
ULC Soulagent
Postby Kev Fox » Sun Feb 09, 2020 11:02 pm
Check tyres. I get this when front tyre wears. You can feel and see a difference in height from one tread to the next. Might not be your problem but something to check.
Kev Fox
Postby missing lynx » Sun Feb 09, 2020 11:46 pm
Kev Fox wrote:Check tyres. I get this when front tyre wears. You can feel and see a difference in height from one tread to the next. Might not be your problem but something to check.
Good call I once had a problem with a navigator front tyre the blocks wore unevenly giving a choppy ride
Postby Rich Oswald » Mon Feb 10, 2020 9:12 am
Conti block tread are well known for this uneven wear.
Postby Jim » Mon Feb 10, 2020 10:33 pm
Folks I'm pretty sure it's not the front end, however my clutch sprocket has some play, can pull it towards me about 6 mm. Anyone reckon it could be this?
Jim
Postby ULC Soulagent » Tue Feb 11, 2020 11:01 am
That all depends on what clutch type is fitted ;) more info please
ULC Soulagent
Postby Warkton Tornado No.1 » Tue Feb 11, 2020 1:43 pm
Jim wrote:Folks I'm pretty sure it's not the front end, however my clutch sprocket has some play, can pull it towards me about 6 mm. Anyone reckon it could be this?
Six millimetres!
Regardless of whether that is the issue, you should get that fixed before you even start the bike up! I wouldn't even let it out of my garage with only a tenth of that :!:
Seriously, you risk breaking your neck, because even with the renowned Lambretta riders' habit of the 'hovering left hand' pulling the clutch will have no effect if that transmission locks up.
Postby Andyf » Tue Feb 11, 2020 4:29 pm
with it off the ground, does your rear wheel rotate inline?
Andyf
Postby Jim » Tue Feb 11, 2020 10:55 pm
Andyf wrote:with it off the ground, does your rear wheel rotate inline?
Yes no problem
Jim
Postby Jim » Tue Feb 11, 2020 10:57 pm
Six millimetres!
Ok It may not be 6mm, but has got a bit of play
Jim
