Heli coils
Heli coils
Postby gizmo » Mon May 06, 2024 10:43 am
Are the top two threads on a horncasting deep enough to fit a Heli coil.
gizmo
Re: Heli coils
Postby Toddy » Mon May 06, 2024 11:54 am
gizmo wrote:Are the top two threads on a horncasting deep enough to fit a Heli coil.
Yes you can get different length helicoils though
Re: Heli coils
Postby gizmo » Mon May 06, 2024 3:13 pm
Nice one Thanks Toddy. Just ordered some.
gizmo
Re: Heli coils
Postby LambrettaMarky » Tue May 07, 2024 10:09 am
Something I tend to do nowadays with any helicoil and especially so when they're into ally, is to soak the helicoil in thread lock (Green, so a strong one) & then run a tap through it when it's had time to dry.
Should last pretty much forever then.
You can also stack them so having shorter ones is generally a good idea as shortening a longer helicoil can leave a sharp edge at the top.
LambrettaMarky
Re: Heli coils
Postby hullygully » Wed May 08, 2024 10:41 am
+1
just done mine with a 5mm long M5 8-)
Re: Heli coils
Postby Fast n Furious » Wed May 08, 2024 8:40 pm
LambrettaMarky wrote:Something I tend to do nowadays with any helicoil and especially so when they're into ally, is to soak the helicoil in thread lock (Green, so a strong one) & then run a tap through it when it's had time to dry.
Need to be a bit careful about running a tap down the inside of a Helicoil.
You've got 2 very hard materials here. The tap can snatch and bind to the Helicoil usually resulting in dissapointment.
I prefer to use a standard soft screw and run it in and out with some Toothpaste to bed the thread. Sounds a bit unconventional but it works.
if you need to shorten a Helicoil,then I find the slitting disc on a Dremmel works best. Deburring the cut afterwards is paramount. ;)
Re: Heli coils
Postby LambrettaMarky » Fri May 10, 2024 9:47 pm
We all have our ways. I have found that Helicoils just need a clean through & alignment once inserted which is where the tap has helped me over the years. You're not removing material with the tap, as like you say they are HARD...
LambrettaMarky
Re: Heli coils
Postby Storkfoot » Sat Nov 07, 2026 8:32 pm
I have just used an 1.25 pitch M8 Helicoil (well, a cheap Chinese version actually) through steel of about 10mm. It seems to have taken pretty well albeit that it is not at 90 degrees precisely.
I have never done one before. My question is related to not using any loctite. In fact, the coil is probably infused with cutting fluid.
The thread won’t be constantly tightened up and released but neither will it not be used.
Does that sound okay to leave as is?
Re: Heli coils
Postby dickie » Mon Nov 09, 2026 8:04 am
I'd be perfectly happy with that. As long as the parent material is thicker than the helicoil is long, it's got as much hold as it can get. 20mm steel won't be any better than 10mm.
Re: Heli coils
Postby LambrettaMarky » Mon Nov 09, 2026 12:50 pm
Storkfoot wrote:I have just used an 1.25 pitch M8 Helicoil (well, a cheap Chinese version actually) through steel of about 10mm. It seems to have taken pretty well albeit that it is not at 90 degrees precisely.
Paul - the worst that can happen is the helicoil can pull out which is fairly unlikely.. if that does happen then try the loctite trick, failing that leave it be..
Mark
LambrettaMarky
Re: Heli coils
Postby Warkton Tornado No.1 » Mon Nov 09, 2026 4:26 pm
Helicoils - or wire thread inserts - are fitted as standard in many environments, Aerospace, Motorsport etc to add the strength of a ferrous material to a much softer, lightweight alloy in a very compact manner. They are also used extensively as a means of repair & I have from M4 to M8 - including M7 - & spark plug thread kits.
The insert - if fitted not perpendicular - is completely unaware & will function as it should, regardless :D
As for the practice of running a tap through to ‘seat’ the insert properly, I have resorted to this, but I’d rather not do so, especially when the insert is stainless. Stainless steel can very easily ‘gall’, work harden & even cold weld to any cutting tools. I’ve known skilled fitters have taps get jammed & break so when I’ve done it, I’ve had my heart in my mouth, though that’s probably understandable if the insert length is 3D or more, as with crankcase thread repairs….
Re: Heli coils
Postby Storkfoot » Mon Nov 09, 2026 10:38 pm
dickie wrote:I'd be perfectly happy with that. As long as the parent material is thicker than the helicoil is long, it's got as much hold as it can get. 20mm steel won't be any better than 10mm.
I think the helicoil is about 1 or 2mm longer. I’ll keep an eye on it.
Thanks for the replies.
Re: Heli coils
Postby dickie » Tue Nov 10, 2026 7:13 am
I'd be slightly nervous about the helicoil being too long for the material. You can buy short ones, or shorten them yourself. Pretty obvious, but just make sure you cut the end without the tang. Important not to bend it as you cut it, a really good pair of side cutters is necessary or you'll end up with rough thread entry.
Re: Heli coils
Postby Warkton Tornado No.1 » Tue Nov 10, 2026 9:25 pm
dickie wrote:I'd be slightly nervous about the helicoil being too long for the material. You can buy short ones, or shorten them yourself. Pretty obvious, but just make sure you cut the end without the tang. Important not to bend it as you cut it, a really good pair of side cutters is necessary or you'll end up with rough thread entry.
Good advice & best to have a significant countersink at 90°at the entry point, though ‘best practice’ is both sides. I mention it as you might want to bear that in mind when shortening the insert.
It sounds as if your inserts are 1-1/2 D (12 mm) & 1 D would be the better option. How many do you need? I have more 1 D - & other lengths - than I’ll possibly ever need so if, say, two or three would mean you have spares to hand, I’ll happily post them up to you :D
Re: Heli coils
Postby Storkfoot » Tue Nov 10, 2026 10:48 pm
Thanks for the offer. I only needed the one which is why I went for the cheap Chinese version though.
Users browsing this forum: bennn and 31 guests
