Eibar TV175 SII
Eibar TV175 SII
Postby Digger » Mon Mar 09, 2015 3:22 pm
What's going on here - I don't recall seeing this before?
Digger
Re: Eibar TV175 SII
Postby HxPaul » Mon Mar 09, 2015 4:23 pm
Digger wrote:What's going on here - I don't recall seeing this before?
If its the parts that have been machined out of the case that you're meaning,I think its so the bearing can be knocked out without damaging it and can be used again.
Re: Eibar TV175 SII
Postby Digger » Mon Mar 09, 2015 4:45 pm
Ok seems like a lot of work to save a bearing... :?
Digger
Re: Eibar TV175 SII
Postby rossclark » Tue Mar 10, 2015 12:56 am
Takes about 10 mins, I thanked myself for doing it in my engine last time when I fitted the pigging bearing with the seal towards chain side ... :oops:
Re: Eibar TV175 SII
Postby Bettagetabrettabolti » Tue Mar 10, 2015 1:25 pm
I have a Spanish Winter model S2 and mine is definitely not like this but don't be worried it will not affect the bike in anyway.
Thing to remember is......... You still want heat to force out the bearing and replace the new one. Don't just put a punch on the outer flanges of the bearing and try to knock it out as you could damage and crack the casing - heat is DEFINATELY required.
Bolti
Re: Eibar TV175 SII
Postby Totally » Tue Mar 10, 2015 1:46 pm
I have seen lots of Spanish engines but never seen this modification. It will be an owner modification and is not something that is specific to Spanish TV's. Cheers Perry.
Totally
Re: Eibar TV175 SII
Postby Digger » Tue Mar 10, 2015 3:17 pm
Thanks chaps - it's been done very well so whoever did it had access to a decent workshop.
Digger
Re: Eibar TV175 SII
Postby nickw » Tue Mar 10, 2015 8:12 pm
I've seen this mod before just can't remember where!
nickw
Re: Eibar TV175 SII
Postby Adam_Winstone » Tue Mar 10, 2015 8:33 pm
People I know have done this to SI cases to improve oil flow / lubrication of the bearing, which makes sense on a SI as it does not accept an oil thrower washer/assembly. On a later casing....?
Re: Eibar TV175 SII
Postby soullad » Tue Mar 10, 2015 9:36 pm
Totally wrote:I have seen lots of Spanish engines but never seen this modification. It will be an owner modification and is not something that is specific to Spanish TV's. Cheers Perry.
+1 has to be owner/ shop/ mechanic specific.
Any pics of the scooter, is it a winter TV or an earlier one?
soullad
Re: Eibar TV175 SII
Postby Digger » Tue Mar 10, 2015 10:39 pm
It is a Winter model TV with matching numbers.
It's currently stripped having just come back from acid dipping - the previous owner had, for reasons unknown, had all the steel powder coated - poorly at that.
Digger
Users browsing this forum: Google [Bot] and 7 guests
