MK Monty wrote:Been thinking about the switch side of it and I like the idea of the modified LI switch. I know a single toggle switch on some form of bracket is the simplest, but I dont like the look. Rocker switches are another way but you have to push the opposite side to turn the buggers off and with gloves on it will be harder still.
Yep, I can vouch for that, I tried 2 toggle switches and the 2nd one with a waterproof rubber cover over it worked well but I decided to change to the Li type which is as you say a pain in the arse to operate especially with winter gloves on. The Honda Cub solution mentioned above is seriously neat and I will be following this route soon.
